Old 02-22-2009, 02:52 PM   #18
cdog999
cdog999 is on a distinguished road
Default Re: Estimating 89 inch lbs without Torque Wrench (Valve Cover Gasket replacement)
Update: I was able to get the old gasket off the valve cover using a box cutter and some twisting and turning
But, what the heck are the 11 valve cover grommets used for? I can't see any reason to use them, or how I even would use them with the 11 bolts. Why are these provided with the Fel-pro Gasket kit? Are these even needed (I can't get the bolts all of the way off, they stay on the valve cover...)?
Add to cdog999's Reputation
Rate the quality of this post and help cdog999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cdog999 is offline   Reply With Quote
