Old 02-22-2009, 02:38 PM   #17
Default Re: Estimating 89 inch lbs without Torque Wrench (Valve Cover Gasket replacement)
They break? Huh. 89in lbs, if in lbs directly converts to ft lbs is roughly 7ft lbs. I'd estimate that the ECTS gets tightened roughly the same as the VC bolts, so if you break the bolts you'd probably also break the ECTS
