Old 11-25-2006, 10:16 PM   #4
HeroHog
HeroHog is on a distinguished road
HeroHog's Avatar
2007 ION-3 Quad Coupe
Checkered Flag Re: Car Math. Calculate anything!
Here, this should make up for that:
1/4 mile ET = 1/8 mile ET x 1.5832
1/8 mile ET = 1/4 mile ET / 1.5832
1/4 mile ET = ((Weight / HP)^.333) * 5.825
1/4 mile MPH = ((HP / Weight)^.333) * 234
HP = (Weight / ((ET/5.825)^3))
HP = (((MPH / 234)^3) * Weight)
NOTE: pi/4 = 0.7853982
cylinder volume = pi/4 x bore^2 x stroke
stroke = displacement / (pi/4 x bore^2 x number of cylinders)
compression ratio = (CylVolume + ChamberVolume) / ChamberVolume
chamber volume = cylinder volume / compression ratio - 1.0
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
piston speed in fpm = stroke in inches x rpm / 6
rpm = piston speed in fpm x 6 / stroke in inches
horsepower = rpm x torque / 5252
torque = 5252 x horsepower / rpm
theoretical cfm = rpm x displacement / 3456
volumetric efficiency = actual cfm / theoretical cfm x 100
street carb cfm = rpm x displacement / 3456 x 0.85
racing carb cfm = rpm x displacement / 3456 x 1.1
effective ratio = (old tire diameter / new tire diameter) x original ratio
actual mph = (new tire diameter / old tire diameter) x actual mph
drive wheel torque = flywheel torque x first gear x final drive x 0.85
wheel thrust = drive wheel torque / rolling radius
g = wheel thrust / weight
weight transfer = weight x cg height / wheelbase x g
lateral acceleration = 1.227 x raduis / time^2
lateral weight transfer = weight x cg height / wheel track x g
centrufugal force = weight x g
rpm after shift = ratio shift into / ratio shift from x rpm before shift
driveshaft torque = flywheel torque x transmission ratio
actual mph = 3600 / seconds per mile
speedometer error percent = difference between actual and indicated speed / actual speed x 100
indicated distance = odometer reading at finish - odometer reading at start
odometer error percent = difference between actual and indicated distances / actual distance x 100
mph = (rpm x tire diameter) / (gear ratio x 336)
rpm = (mph x gear ratio x 336) / tire daimeter
gear ratio = (rpm x tire diameter) / (mph x 336)
tire diameter = (mph x gear ratio x 336) / rpm
percent of weight on wheels = weight on wheels / overweight x 100
increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
center of gravity behind front wheels = rear wheel weights / overall weight x wheelbase
center of gravity off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
Hero Hog
07 Ion QC 3 2.2L
Add to HeroHog's Reputation
Rate the quality of this post and help HeroHog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HeroHog is offline   Reply With Quote
