Old 11-10-2017, 07:04 PM   #5
Default Re: 2009 Astra Diagnostic Error Codes, diagnostic help needed
P0301 is a misfire in cylinder#1 while P0313 is a misfire detected with low fuel; https://www.engine-codes.com/p0313.html. Astra members here may have better info. Did you run the fuel tank to close to empty?
Whoever did the wheels and oil may have used gorilla techniques using a pneumatic impact wrench set for 3 million ft-lbs.......... Morons do this in laziness instead of learning what t-o-r-q-u-e [tork] means and using finesse if they insist on using pneumatic impact tools.
