Old 11-10-2017, 05:02 PM   #2
Default Re: Baldwin fuel filter--what are these extra pieces?!
The inlet side of the existing filter should have a slip on connector with 2 tabs sticking out of it pointing towards the fuel pump body. You squeeze the tabs and carefully slide the connector off of the old filter and then onto the new filter. It inserts to the point you hear the latch click over that ring on the inlet tube. Should not need those extra fittings.
What is actually there depends on how bad it has been hacked over time.
