Old 11-10-2017, 03:10 PM   #2
toggenburg
toggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to behold
toggenburg's Avatar
Default Re: Elusive high idle issue - 2001 SL1
Anyone check for valve cover seal issues?
With engine idling, using a spray can of brake cleaner, or the like, spray along the entire outer rim of the valve cover. If there is a vacuum leak, the idle will SOAR....then calm down a bit until resprayed. If so, it would mean a simple gasket replacement job.
