Thread: Timing belt
Old 11-10-2017, 08:27 AM   #7
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: Timing belt
If the engine is well cared for and there are no weird drives off the chain (i.e. early EcoTec 4 cylinders used the timing chain on the water pump) it should last the same as the engine itself. At 277k as you noted there is no need to do anything unless (as noted) you're hearing bad noises. Otherwise just keep running it until the engine gives up the ghost and needs to be overhauled or replaced
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
