Thread: no start urgent
Old 10-06-2017, 01:00 PM   #10
Default Re: no start urgent
Hard to bump/push start any vehicle if the key isn't left in "run"
I believe using a higher gear than 1st, like 2nd or maybe 3rd works better, the engine only needs to be spun to about 300rpm before it'll run on it's own.
If the lights look normal that suggests that the power level is okay and the battery cables are fine. Doesn't mean they are fine as the starter requires more power to do any work (even "click") than any of the lights do, but without a volt-meter of some sort you gotta work with whats "on hand".
Not sure where the best place would be from the top to reach the starter, you really want to hit the middle of it which means snaking something between intake runners 2 & 3 (not a 2x4...), but you might be able to reach the end of it with careful aim sorta from the battery & under the fuel line bracket under the intake manifold.
