Old 10-06-2017, 05:58 AM   #11
Signmaster
Default Re: 19999 SW1 temp gauge behaving oddly after radiator replacement
While you are in there anyway, check the line that dumps into the back of the reservoir for a solid flow stream. It can be done with the line on the reservoir, but I've found that taking it off it probably just as easy and you can see the flow better. Just disconnect, dump it in the (open) reservoir, and then check flow after starting the car. Best done with the car cool.
The single cammers don't generate a lot of heat, so if it's heating up quickly the line could be suspect.
