Old 10-05-2017, 04:11 PM   #13
Kaspar7
Kaspar7 has a spectacular aura aboutKaspar7 has a spectacular aura aboutKaspar7 has a spectacular aura about
1999 SW1
Default Re: 19999 SW1 temp gauge behaving oddly after radiator replacement
the temp gauge is not a precision instrument, so running about 3/8~1/2 is "normal." You may not be really running hot at all.
it's running really hot now; went clear up to the red zone and the Hi-Temp light came on. Fan isn't coming on. Bought a new fan motor and replaced that. But now I can't find that ONE bolt that holds the fan shroud to the radiator. I put it in a magnetic parts tray when I took it out, to prevent losing it!! That bolt was missing when I got the car. Found a replacement in my collection of old nuts 'n' bolts. But didn't think to get a spare before I put it in the car. Now it's gone. Moved the car far enough (downhill in neutral, not cranked) to look all under it. No luck.
Add to Kaspar7's Reputation
Rate the quality of this post and help Kaspar7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaspar7 is offline   Reply With Quote
