Old 10-05-2017, 04:09 PM   #11
Claybury will become famous soon enough
Claybury's Avatar
Default Re: Slight Shake with New Brakes
All else being equal it sounds like resin transfer onto the rotors. With new pads and, possibly oil on the new rotors, you can get glazing if you make a hard or long stop and then sit at a light with the wheel not moving. If you can see a ghost pattern of the pad anywhere on the rotors or a different coloration on the rotor surface you will have to de-glaze the surfaces and redo the pad break in.
Pre-baked pads are supposed to help. I still do a burn-in run on them anyway.
If you do have new pads and get stuck at a light give yourself enough room to creep forwards until the brakes can cool a little.
Shakes while coasting can be a few things. Folks often overlook the tires.
Dura-last, meh. Haven't used them on a Saturn. Didn't care for them on trucks.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
