Old 10-05-2017, 10:30 AM   #2
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: 19999 SW1 temp gauge behaving oddly after radiator replacement
First and foremost pressure test the cooling system. If you don't you're just pi$$ing into the wind. Once you affirm the system can hold pressure buy a new pressure cap for the coolant tank. Cheap insurance. Properly bleed the cooling system to be sure all air is out.
Odds are (other than the hissing) it's now just operating normally now that the ECTS is fully covered in coolant and there is no air leak into the system
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
