Old 09-30-2017, 04:32 PM   #1
Bee is on a distinguished road
Default Windshield washer issues
Since I've had my Vue the washer fluid sprays weak, in two little streams that spirt up the glass maybe 8 inches. The pump works.. I can hear it. I was considering buying new nozzles and just went out there to try to clear the nozzles first, just to be sure they weren't just clogged. Well now when I attempt to spray the fluid, it puddles onto the ground from under the driver side somewhere, so obviously a line is broken or detached. I can't find a hose diagram anywhere online... anyone here have one or have any advice on an easy way for a female with limited mechanical skills to fix?
Add to Bee's Reputation
Rate the quality of this post and help Bee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bee is offline   Reply With Quote Sponsored Links
