Old 07-16-2017, 12:57 PM   #2
Default Re: 2009 Astra Diagnostic Error Codes, diagnostic help needed
P0300 is a general misfire for all four cylinders, P0301 is for misfiring in cylinder #1. If you search past threads within the Astra forums, you may see a repeating failure pattern of coil packs.
Googling for each error code will provide many sites with code definitions.
