Old 05-02-2017, 10:48 PM   #3
tvanhaitsma is on a distinguished road
Default Re: C0045 code after bearing and sensor replaced
Thanks for the response.
It is recommended that when changing the hub assembly you pull out the abs sensor to avoid damage. However, it broke when I pulled it out so I was forced to replace it. I used Moog bearing assemblies with both a BWD sensor and a NAPA sensor. The two new sensor and the original sensor all look almost identical. There is a slight difference in the way the sensor latches to the factory harness but it does still snap into place.
It has to be an electrical issue so I am going to try and find a schematic and start troubleshooting next.
I use the Blue Driver from Lemur Monitors which pairs to my Android phone. I have been very happy with it.
Add to tvanhaitsma's Reputation
Rate the quality of this post and help tvanhaitsma reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tvanhaitsma is offline   Reply With Quote
