Old 09-19-2016, 09:38 PM   #1
joeyw82 is on a distinguished road
Default Freon leaking due to hole
Was hoping someone could help me identify which hose/part number is in this picture. image.jpg The picture is upside down for some reason when uploaded but these are located behind the engine next to the firewall/cab. The host with the metal fitting rubbed against the tube behind it and caused a pin hole that I was able to track down using dye. I have a feeling it's the most expensive, around $500, part thst I'm seeing online.
Add to joeyw82's Reputation
Rate the quality of this post and help joeyw82 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joeyw82 is offline   Reply With Quote Sponsored Links
