Old 04-08-2014, 09:06 PM   #14
Ignatz is on a distinguished road
2006 ION-2 Quad Coupe
Default Re: Have You Experienced the Ignition Switch Issue?
Sorta. Had a mirror image of the problem about 6 months ago. Wifey got to work one morning and couldn't shut it off. It didn't shut itself off, in fact it wouldn't shut itself off. The switch would turn to the off position, but the engine kept on running, and running, and running. So-o, some nice fella from the Munro shop next door pulled a fuse to stop it. The GM dealer replaced the switch to the tune of around $500. Think we'll get any reimbursement from GM? They replaced the ignition switch. We just got the recall notice, so now I wonder if GM doesn't know it was replaced, or if they replaced it with another defective part. As I said, the work was done by a GM dealer. I'll check back when we've gotten it in.
Add to Ignatz's Reputation
Rate the quality of this post and help Ignatz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ignatz is offline   Reply With Quote
