Old 03-27-2014, 01:12 PM   #6
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: Have You Experienced the Ignition Switch Issue?
iv never seen the plastic clip. im still debating whether i should go in for the ignition lock swap or not, since i never had an issue with my car, and afraid that after it gets changed, someone else will go wrong. I like to go "if it isnt broken, it doesnt need to be fixed".
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin.st56 is offline   Reply With Quote
