Old 03-25-2014, 08:07 PM   #1
mars2878 is on a distinguished road
Default i helped to save a saturn today
an 01 sc1 auto w/158k mi. was junked @ my work late yesterday. the car failed inspection due to the suspension. her mechanic told her it would be about $1k to repair. the car body was clean w/ only a little scale behind the
3rd dr. driver seat showed some wear on the outer bolster. sunroof only moved up & down about a 1/2in, did not appear to leak. new front struts. ea pit in trunk had a small hole drilled in it, probably took on water @ some point. valve cover leaked. ran quiet, drove good & thermostat @ proper level. so I put the car out front this morning for sale. the car was sold by lunch. the coupe would've went to crush because we replaced all of the s-series in the last few weeks. the cust is picking up the coupe tomorrow. this is getting a second lease on life.
Add to mars2878's Reputation
Rate the quality of this post and help mars2878 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars2878 is offline   Reply With Quote Sponsored Links
