Old 02-09-2014, 01:12 PM   #1
haloelite482 is on a distinguished road
Default 2004 vue ignition switch issue
So I started having the car wont start in really cold weather and discovered it was the ignition switch, so I switched my old one for a new one and when I went to do the relearn passlock procedure, my car just started up normally. Does this mean it wasn't the ignition switch, because I had the security light blinking when my car wouldn't start which is what happens when the issue is the ignition switch. Anyone else had this happen to them? Should I be worried?
Add to haloelite482's Reputation
Rate the quality of this post and help haloelite482 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haloelite482 is offline   Reply With Quote Sponsored Links
