Old 03-27-2013, 05:58 AM   #1
James614 is a jewel in the roughJames614 is a jewel in the roughJames614 is a jewel in the rough
Default 2007 Ion startig issue (not ignition switch!)
Okay, so have a weird issue. The car was running fine until after sitting for 2 weeks where the battery died. I guess the passlock relearn had to be done afterwards, but in the process of troubleshooting the starter was replaced with a reman. Now, the car tries to start normally, but the starter spins without turning the engine. I had the starter tested and it spins rapidly and extends as it should. The teeth on the flywheel and starter are intact. Is there an electrical issue that could cause this?
Add to James614's Reputation
Rate the quality of this post and help James614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
James614 is offline   Reply With Quote Sponsored Links
