Old 02-06-2012, 03:17 PM   #1
SlowRide
SlowRide is on a distinguished road
SlowRide's Avatar
1998 SW2
Default How Urgent is TPS replacement?
I've had my '98 SW2 for about 2 months and it seems that the TPS is failing, from what I've read here in the forums. A couple times the idle stayed high, ~1500 rpm, after driving ~45 minutes. The first time I tapped the accelerator and it went back to normal which was ~850rpm. I cleaned the TB (in place) and after that it has been idling at 800. about 6 weeks later, I had another episode of high idle, which did not go away with tapping the accelerator, but went away after turning the car off and restarting. Does this sound like a failing TPS? Can the TPS failure cause the car to be undrivable?
1998 SW2 5spd 66k mi
1999 C5 hardtop
2007 Magnum SRT8
Add to SlowRide's Reputation
Rate the quality of this post and help SlowRide reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlowRide is offline   Reply With Quote
