Thread: Flex Pipe???
Old 12-01-2011, 10:31 AM   #3
FooBag
FooBag is on a distinguished road
2008 Astra XR
Default Re: Flex Pipe???
Any exhaust shop should be able to cut out the existing flex pipe and weld in a new one. It's only about 4" long and shouldn't be that expensive. From the factory, it is welded to the front manifold & cat converter, so I suspect the dealer was trying to obtain the entire manifold for you. Just take it to a decent exhaust shop and they will be able to replace it for you.
2008 Astra XR3
2012 Silverado Crew Cab
Add to FooBag's Reputation
Rate the quality of this post and help FooBag reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FooBag is offline   Reply With Quote
