SaturnFans.com Forums
-   General Saturn Discussion (http://www.saturnfans.com/forums/forumdisplay.php?f=10)
-   -   wrecked front end (http://www.saturnfans.com/forums/showthread.php?t=207840)
dirtball07 04-29-2015 09:56 PM
wrecked front end
I have a 1996 sl2 44000 original miles that was involved in a front end accident I have a replacement car on hand now for parts but looking at the damage I noticed most of the framework is spot welded, does anyone have any info on how to replace basically the front framework?
54packman 07-10-2015 07:25 PM
Re: wrecked front end
Done many, you need a spot weld cutter, to drlll all the spot welds, and a welder to put it back in. If its only the rad support I can have them done I. A few hrs but if the frame rails are bent it needs to be pulled out straight before the rad support will fit and line up the head lights and the hood latch and the fenders, its a lot of work, and vise grips to hold things temporary to check alignments
