SaturnFans.com Forums
-   S-Series Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=39)
-   -   ignition coils? anything better then stock? (http://www.saturnfans.com/forums/showthread.php?t=156658)
starnes892 07-23-2010 01:55 AM
i was doing some looking and found some accel coils and found that most v6 gm engine coils will work with mod. does the stock coil drop volts after it gets rusty?
I have installed low ohm wires. (obx)
bbarbulo 07-23-2010 01:57 AM
Re: ignition coils? anything better then stock?
it's generally agreed that the BEST setup is the original stuff. even the OBX wires take away from system reliability. same goes for ignition coils.
OldNuc 07-23-2010 10:18 AM
The aftermarket coils are all junk, use good condition stock OEM. You can use Magnecore wires if you want but other than the Magnecor wires stay with the regular carbon fiber wires.
starnes892 07-23-2010 10:58 AM
from what i seen the obx wires make a big difference with how my car runs e85. and i was looking for a better coil but i havnt talk to anyone personally but i have read that replacing the coils with the ones out of a gm v6 work better the stock but would like more input on this.
SLCraig 07-23-2010 12:09 PM
I tried ACCEL coils. One of them failed.
I went back to a stock setup I pulled from a wrecker car... problem free.
Don't waste your time.
alordofchaos 07-23-2010 12:25 PM
[QUOTE=starnes892;1642113]from what i seen the obx wires make a big difference with how my car runs e85. [/QUOTE]Ah, you didn't mention the E85 before :)
[QUOTE]i was looking for a better coil but i havnt talk to anyone personally but i have read that replacing the coils with the ones out of a gm v6 work better the stock but would like more input on this.[/QUOTE]
You mean like this?
[url]http://www.saturnfans.com/forums/showthread.php?t=156186[/url]
I don't know if they "work better" or are just less prone to corroding.
starnes892 07-23-2010 12:58 PM
with the accel did have any improvements? and alordofchaos thats what i was talking about they are a different type because they use them on the supercharged engines so i figured they would be better then the stock saturn coils
SLCraig 07-23-2010 01:04 PM
I noticed no difference over stock, with the Accel coils.
Until one day my car was running on 3 cyl. That was a bit of a difference.
I returned them for a refund and went back to stock.
starnes892 07-23-2010 01:07 PM
yea a 4 cyl running on 3 cyl isnt a fun thing.
Low Saturn 07-23-2010 01:11 PM
I've had great success with Accel and Jegs coils. They're not any better than new OEM coils. But they can be found cheaper and are just as reliable.
The only way new coils, aftermarket or OEM would gain any performance improvment is if the originals are shot.
sattyluvr 07-23-2010 11:22 PM
i had 2 accel coils in my sc2 thinking they'd be a lil better
wrong!
both died within a month of each other about a couple thousand miles in
biggest waste of money ever!!!
from what ive heard the stock system is the best
starnes892 07-24-2010 02:17 AM
thanks guy for the input was looking for a different answer but i am glad i wont be wasting any of my money!
