SaturnFans.com Forums
-   Vue General (http://www.saturnfans.com/forums/forumdisplay.php?f=91)
-   -   Code P0420 (http://www.saturnfans.com/forums/showthread.php?t=233617)
Johnsonjf 01-22-2018 01:30 PM
Code P0420
I have a 2008 Saturn Vue Redline with 193K miles. Iím getting code P0420, Iíve replaced the O2 sensor and still have the same code. Is there any thing else I can do to fix this or is replacing the catalytic converts the only option?
Thank you,
Jeff
guyg 01-22-2018 06:24 PM
Re: Code P0420
Carefully check for small exhaust leaks between the front and rear O2 sensors, especially the flex hose. A shop vac can supply air to pressurize the exhaust, use a soap and water solution to check for any bubbles. Any slight leak may set a code.
