SaturnFans.com Forums
-   Astra General (http://www.saturnfans.com/forums/forumdisplay.php?f=105)
-   -   buying astra: carfax shows engine wiring repaired/alternator replaced. Why??? (http://www.saturnfans.com/forums/showthread.php?t=193540)
brice017 08-01-2013 08:23 AM
Was about to purchase an Astra from dealer, when I pulled the Carfax.
1/2012 maintenance inspection completed:
battery/charging system checked
alternator/generator replaced
No dealer service on carfax since.
Not knowing much about these cars, is this a common issue?
Should I avoid this car?
It's a great deal. I was going to purchase and have it shipped to me, as similar cars are 4K+ higher in the mid-atlantic.
Any insight would be much appriciated.
smwalker 08-02-2013 03:03 AM
Re: buying astra: carfax shows engine wiring repaired/alternator replaced. Why???
Hey brice. Have not heard of wiring problems that are common. With the alternators there was a chirping with the AC on. Soloution was to replace the pulley. But it needed a special tool that none if the gm dealers had so they ended up replacing the whole alternator in some cases.
Could be that, maybe.
Get on yelp.com and find a well reviewed mechanic near the seller and have them take it over there for an inspection. Cost you 100, but could save you thousands.
Good luck!
Astra La Vista! 08-02-2013 04:13 PM
[QUOTE=brice017;1998158]Was about to purchase an Astra from dealer, when I pulled the Carfax.
Any insight would be much appriciated.[/QUOTE]
Alternator may have short circuited internally, damaging it and the surrounding wiring.
Mid-atlantic? As in, the Azores? Might want to ask on the European forums if this is the case.
